Industrial Intelligent Non-contact Liquid Level Sensor (IP67)
$19.90
SKU: SEN0716
  • $19.40 3+ items
  • $18.90 5+ items
  • $18.30 10+ items
The Intelligent Non-contact Liquid Level Sensor detects liquid presence through non-metallic container walls using capacitive sensing. It supports one-button automatic sensitivity calibration and provides high/low level output for integration with microcontrollers.
This intelligent non-contact liquid level sensor uses capacitive sensing to detect liquid presence through container walls, eliminating direct contact with corrosive, viscous, or contaminated liquids. The sensor compensates for residual films, moisture, or foam in liquids such as milk, honey, latex, blood, engine oil, and acid/alkaline solutions, delivering reliable level detection. A built‑in LED indicator shows real‑time status, and the IP67‑rated PC‑V0 housing ensures stable operation in harsh industrial or outdoor environments. This sensor works seamlessly with Arduino and other 5V logic microcontrollers.
How to use Industrial Intelligent Non-contact Liquid Level Sensor
One‑Touch Automatic Sensitivity Calibration
The sensor features an intelligent sensitivity memory function with external push‑button control. Simply ensure liquid is present at the sensing position and single‑click the button. Within 3‑5 seconds, the sensor automatically locks onto the optimal sensitivity for the current container wall thickness and material. This eliminates manual tuning and adapts to plastic, glass, or ceramic containers up to 10mm thick.
Non‑Contact Detection for Demanding Liquids
Because the sensor mounts on the outer container wall, it never touches the measured liquid. This avoids corrosion from strong acids or alkalis, prevents contamination in medical or food applications, and eliminates fouling from sticky substances like honey, latex, or engine oil. The non‑contact design also simplifies cleaning and maintenance in hygienic environments.
Penetrates Non‑Metallic Containers with High Sensitivity
The advanced capacitive sensing technology works through plastic, glass, and ceramic walls with a sensing distance (wall thickness) up to 10mm. It detects low‑conductivity liquids (≤50ms) and compensates for residual moisture or foam that would confuse ordinary sensors. The built‑in high‑precision IC converts minute capacitance changes into a reliable high/low level signal.
Industrial‑Grade Robustness
The housing is molded from PC‑V0 fire‑retardant material, and the IP67 waterproof rating protects against dust and temporary immersion. An onboard LED indicator provides instant visual confirmation of liquid presence. With an operating temperature range of ‑25°C to +85°C and temperature drift below 20%, this sensor performs reliably in refrigeration, outdoor tanks, and industrial machinery.
Diagram of Intelligent Non-contact Liquid Level Sensor
From water shortage protection in household dispensers and coffee machines to liquid level monitoring in medical equipment and strong acid/alkali storage tanks, this non‑contact sensor delivers corrosion‑free, maintenance‑reduced level detection. It also suits sealed chemical containers and toxic liquid monitoring where any leak would be hazardous.
  • One‑touch automatic sensitivity calibration with memory function
  • Non‑contact detection – mounts outside the container, no liquid contact
  • Works through plastic, glass, and ceramic walls up to 10mm thick
  • Detects viscous liquids (milk, honey, latex, blood, oil, acids/alkalis) with residual film or foam
  • Built‑in LED indicator for real‑time level status
  • IP67 waterproof and PC‑V0 fire‑retardant housing
  • High/low level digital output, compatible with 5V systems
  • Household appliances: Water shortage protection and water level control for water dispensers, water purifiers, coffee machines
  • Medical equipment: Liquid monitoring for medical solutions and liquid level management for medical cleaning equipment
  • Industrial control: Liquid level detection in strong acid and strong alkali storage tanks, monitoring of toxic liquids in sealed containers
  • Chemical industry: Liquid detection in high-pressure sealed containers
    Applications of Intelligent Non-contact Liquid Level Sensor
    Electrical Characteristics
  • Operating Voltage: 5V DC
  • Current Consumption: ≤10mA±2mA
  • Output Type: High/Low Level
  • Output Current: ≤100mA
  • Power-on Delay: ≤500ms
  • Response Time: ≤100ms
  • Detection Performance
  • Sensing Thickness Range: ≤10mm
  • Liquid Level Accuracy: ±3mm
  • Detectable Liquid Conductivity: ≤50ms
  • Environmental & Physical
  • Operating Ambient Temperature: -25°C~85℃
  • Operating Ambient Humidity: 30%~80% non-condensing
  • Temperature Drift: ≤20% (-25℃~+60℃)
  • Cable Length: 50cm
  • Housing Material: PC-V0 fire-retardant material
  • Waterproof Rating: IP67
  • Intelligent Non-contact Liquid Level Sensor x1
