SRF02 Ultrasonic Distance Sensor (16~600cm)
$18.50
SKU: SEN0005
Low-cost ultrasonic ranger with I2C and Serial interfaces features AutoTune for optimal performance, measuring range 16cm-6m, power 5V, and supports up to 16 devices.
SRF02 Ultrasonic Distance Sensor is a compact ultrasonic ranging module designed for accurate non‑contact distance measurement in robotics and embedded electronics. This ultrasonic rangefinder integrates both I2C and TTL serial communication, allowing flexible integration with controllers such as Arduino and other microcontroller platforms. Built around a single 40kHz transducer, this digital distance measurement unit performs precise echo timing internally and reports range data in multiple units. Automatic tuning algorithms and configurable commands allow this ultrasonic sensing board to operate reliably in dynamic environments while maintaining stable measurement performance across a wide sensing range.
Automatic Tuning for Optimal Measurement Performance
This ultrasonic ranging module incorporates intelligent AutoTune algorithms that automatically adjust the minimum detection range close to the transducer ringdown limit. Continuous background optimization ensures the best achievable sensing performance without requiring manual calibration routines. Automatic gain control with 64 adjustable steps further improves signal quality and echo detection reliability. As a result, this ultrasonic measurement board can quickly stabilize after power-up and maintain consistent distance readings even in environments where surface reflections or signal attenuation may affect traditional ranging sensors.
Dual Interface Communication for Flexible Integration
This ultrasonic distance detection board supports both I2C and TTL serial communication interfaces, allowing seamless integration with a wide variety of microcontrollers and embedded systems. The UART interface operates at 9600 baud with a standard configuration of 1 start bit, 2 stop bits, and no parity, enabling direct connection to hardware serial ports. Multi-device support allows up to 16 ultrasonic ranging units to share the same communication bus, making this robotics proximity sensor suitable for distributed sensing arrays and multi-directional obstacle detection systems.
Advanced Command Control for Custom Ultrasonic Operations
Expanded command capabilities enable independent control over ultrasonic burst generation and reception cycles. This ultrasonic measurement module can transmit a sound burst without triggering a measurement cycle or perform echo reception without generating a new burst. Such flexible operation enables experimental acoustic sensing, synchronized multi-sensor systems, and customized ranging workflows. Because transmission and reception share a single transducer element, the minimum measurable range begins at approximately 15cm, while maintaining long‑distance measurement capability reaching several meters.
Reliable ranging performance and flexible communication make this ultrasonic sensing module well suited for robotic obstacle detection, autonomous navigation systems, smart distance monitoring, and interactive electronics projects. This compact ultrasonic measurement board also serves as a practical sensing component in embedded automation, environmental monitoring platforms, and STEM learning environments that require accurate, contact‑free distance measurement.
  • Ultrasonic distance measurement using a 40KHz transducer
  • Dual communication interfaces: I2C bus and TTL serial
  • Supports connection of up to 16 modules on a shared bus
  • Automatic 64-step analogue gain control
  • AutoTune algorithm eliminates manual calibration
  • Independent ultrasonic burst and reception command control
  • Range output selectable in microseconds, cm, or inches
  • Fully timed echo processing reduces host controller workload
  • Robotic obstacle avoidance systems
  • Autonomous vehicle distance sensing
  • Smart parking or proximity detection systems
  • Interactive electronics and embedded sensing projects
  • STEM robotics education platforms
  • Multi-sensor environmental monitoring systems
  • Range: 16cm (6.3in) to 6m (236in)
  • Power: 5v, 4mA Typ.
  • Frequency: 40KHz
  • Size: 24mm (0.9in) x 20mm (0.79in) x 17mm (0.67in) height
  • Analogue Gain: Automatic 64 step gain control
  • Connection Modes: 1 - Standard I2C Bus 2 - Serial Bus - connects up to 16 devices to any uP or UART serial port
  • Full Automatic Tuning: No calibration, just power up and go
  • Timing: Fully timed echo, freeing host controller of task
  • Units: Range reported in uS, mm or inches
  • Light Weight: 4.6gm
  • SRF02 Ultrasonic Distance Sensor x1
