Sharp GP2Y0A21 IR Distance Sensor for Arduino (10~80cm)
$12.00
SKU: SEN0014
The IR distance sensor measures 10-80cm and offers better performance than other IR options. It connects easily to microcontrollers for projects.
Purchase this product and earn 120 reward points, which are tied to VIP membership program. Learn More >
The Sharp distance sensors are a popular choice for many projects that require accurate distance measurements. This IR sensor is more economical than sonar rangefinders, yet it provides much better performance than other IR alternatives. Interfacing to most microcontrollers is straightforward: the single analog output can be connected to an analog-to-digital converter for taking distance measurements, or the output can be connected to a comparator for threshold detection. The detection range of this version is approximately 10 cm to 80 cm (4" to 32"); a plot of distance versus output voltage is shown below.
The GP2Y0A21 uses a 3-pin JST connector that connects to our 3-pin JST cable for Sharp distance sensors (not included) as shown in the upper picture on the right. It is also simple to solder three wires to the sensor where the connector pins are mounted (see the lower picture to the right). When looking at the back, the three connections from left to right are power, ground, and the output signal.
Sharp GP2Y0A21 IR Distance Sensor (10-80cm) For Arduino Related Projects:
How to Build A Smart Cooling Fan with Arduino?
NOTE: All Sharp sensors from DFRobot are shipped with JST cable.
  • Operating voltage: 4.5 V to 5.5 V
  • Average current consumption: 30 mA (typical)
  • Distance measuring range: 10 cm to 80 cm (4" to 32")
  • Output type: analog voltage
  • Output voltage differential over distance range: 1.9 V (typical)
  • Response time: 38 ± 10 ms
  • Package size: 29.5×13.0×13.5 mm (1.16×0.5×0.53")
  • Weight: 3.5 g (0.12 oz)
