IR Kit for Arduino enables reliable infrared remote control functionality for embedded electronics and interactive hardware builds. This infrared remote control kit combines a handheld transmitter with a digital infrared receiver module, allowing physical button presses to trigger programmable actions within microcontroller systems. Designed for smooth integration with Arduino development environments, this compact remote-control solution simplifies wireless command input for robotics, home automation prototypes, and smart device experimentation. The included receiver module and digital cable streamline connection to controller boards while enabling stable decoding of infrared signals from the bundled remote transmitter.
Complete Infrared Remote Control Toolkit
This IR remote control package provides all essential hardware required to implement infrared command input in embedded projects. A handheld infrared transmitter delivers multiple programmable button signals, while the included IR receiver module detects and decodes incoming commands for microcontroller processing. Combined with the supplied digital cable, this remote-control hardware kit forms a ready-to-deploy interface for wireless input. Such a configuration removes the complexity of designing infrared communication circuits and allows rapid prototyping of remote‑operated electronics.
Simple Integration with Microcontroller Projects
This infrared control module set integrates easily into common development workflows for robotics controllers, automation systems, and interactive electronics. The receiver module connects through a standard digital interface, enabling straightforward signal reading and command decoding through widely available infrared libraries. Such compatibility makes the IR control solution suitable for educational experiments, maker prototypes, and remote-operated devices requiring intuitive button-based interaction without complex wireless communication stacks.
Reliable infrared command input expands the interaction possibilities of electronic builds. From remote‑controlled robots and smart home switches to motorized curtain systems and interactive installations, this infrared receiver and transmitter combination enables convenient long‑distance control for many embedded electronics applications and STEM Education experiments.
Basic Parameters
System Compatibility
Nov 18, 2024
Took some time to learn how to program to decode the receiver, but once done it was easier.
May 10, 2023
Very fast shipping. Thanks!
