XL-MaxSonar-WR MB7060-200 Waterproof Ultrasonic Distance Sensor (0~765m, IP67)
$109.50
SKU: SEN0080
The XL-MaxSonar-WR sensor offers long-range detection in a waterproof PVC housing. It outputs sonar data via pulse width, analog voltage, or serial digital formats.
Purchase this product and earn 1095 reward points, which are tied to VIP membership program. Learn More >
The XL-MaxSonar®-WR sensor provides very short to long-range detection and ranging, in a compact, robust PVC housing, designed to meet IP67 water intrusion, and matches standard electrical ¾” PCV pipe fittings. The sensor puts 1/2 watt of peak power into the efficient transformer driving the transducer, yielding high output acoustic power. This acoustic power combined with continuously variable gain, real-time waveform signature analysis, and real-time noise rejection algorithms result in virtually noise-free distance readings for most users.  This holds true even in the presence of many of the various acoustic or electrical noise sources.  The XL-MaxSonar®-WRC1 detects objects from 3-cm to 645-cm (21.2-feet) and provides sonar range information from 20-cm out to 645-cm with 1-cm resolution. Objects from 3-cm to 20-cm range as 20-cm. The interface output formats included are pulse width output, analog voltage output, and serial digital output.
Note: This product has no temperature compensation.
  • MaxModel:MB7060-200
  • 42kHz Ultrasonic sensor
  • Operates from 3-5.5V
  • Supply current: 2.1mA(3.3V)  3.4mA(5V)
  • 10Hz reading rate
  • RS232 Serial Output - 9600bps
  • Analog Output - (Vcc/512)/inch
  • PWM Output - 147uS/inch
  • Designed for outdoor applications
  • Range: 0~765m
  • Ultrasonic Sensor XL-MaxSonar -WR-Water Proof     x1
Only 1 Left
