Flex Sensor 2.2" Bend Resistor (10KΩ-125KΩ Range)
$11.90
SKU: SEN0086
2.2" flex sensor increases resistance when bent. Compatible with breadboards, lifespan over 1 million uses, and operates between -35°C to +80°C.
A simple flex sensor 2.2" in length. As the sensor is flexed, the resistance across the sensor increases. Patented technology by Spectra Symbol - they claim these sensors were used in the original Nintendo Power Glove. I love the Nintendo Power Glove. It's so bad!
The resistance of the flex sensor changes when the metal pads are on the outside of the bend (text on inside of bend).
Connector is 0.1" spaced and bread board friendly.  Check datasheet for full specifications.
Note: The latest version of this product varies on resistance. Please be careful when bending the wiring side of the sensor and note the change on the resistance.
  • Resistance Value: 10KΩ~125KΩ
  • Life Cycle: >1 million
  • Dimension: 77mm * 6mm * 0.43mm (L*W*H)(3x0.2x0.02'')
  • Temperature Range: -35°C to +80°C
  • Flex sensor 2.2" x1
Luis Eduardo.Camayo Sep 23, 2025
Great product Flex Sensor 2.2" Bend Resistor
Ohsoo. Sep 03, 2021
good!!
Out Of Stock
