Gravity: Digital piranha LED module - Blue
$2.60
SKU: DFR0031-B
  • $2.50 2+ items
  • $2.40 3+ items
  • $2.35 5+ items
Blue LED module for Arduino, supports PWM for brightness control. Specs: 3.3-5V, 460-475nm wavelength, 65° angle, 30x22mm, 5g weight. Includes digital cable.
Purchase this product and earn 26 reward points, which are tied to VIP membership program. Learn More >
Piranha LED light module (Blue) , and special sensors Arduino board and ambient light sensor extension combination, can be used in the interaction with the light works.
When the LED light module connected to Arduino, the digital pin (LOW on, HIGH off)  is used to control it. The brightness of LED can be controller via PWM output.
  • Voltage: 3.3~5v
  • Light color: Blue
  • Wavelength: 460~475nm
  • Viewing angle: 65°
  • Size: 30x22mm
  • Weight: 5g
  • Pin Definition
          Digital control pin (support PWM)
          Power Supply
          GND
  • LED light module-Blue          x1
  • Digital Cable (SKU:FIT0011)     x1
Top 4 UNIHIKER Internet of Things (IoT) Projects You Must Try
Projects Top 4 UNIHIKER Internet of Things (IoT) Projects You Must Try
Meimei
Sep 15, 2023
