Gravity: Digital Green LED Light Module
$1.20
SKU: DFR0021-G
Green LED module ideal for Arduino starters, easy to connect on IO/Sensor shield. Includes sensor and digital sensor cable. LED lights up when signal pin is low.
Purchase this product and earn 12 reward points, which are tied to VIP membership program. Learn More >
This green LED light module has a shiny white color. It is ideal for Arduino starter. This module can be easy to be plugged on IO/Sensor expansion shield.
NOTE: This LED is wired to light up when the Signal pin is set to low. The reason for this is to prevent the LED from demanding too much current from the microcontroller and damaging the I/O.
If you wish to make this LED light up with a logic high, you can switch the Signal wire (Green) with the GND wire (Black) and the Voltage wire (Red) to the Signal wire's original spot.
  • Type:Digital
  • LED light module pin definition : (1) control terminal (2) power supply (3) ground
Kaj Ronny.Nilsen Dec 08, 2025
Great LED module which is easy to setup and use, for testing purposes, or even for production as the price is not bad at all. Plugs right into various development boards.
