Nov 08, 2025
Great digital light sensor — accurate, stable, and easy to use! The BH1750 breakout provides direct lux readings over I²C, which makes integration with ESP32 or Arduino extremely simple. I used it in a smart lighting and weather station project, and it performed flawlessly under different lighting conditions. Much more precise than analog photoresistors, and very low power consumption. The board quality is solid, and DFRobot’s documentation makes setup quick. Perfect for IoT, automation, and environmental monitoring projects.
Nov 08, 2025
Excellent little light sensor! The BH1750 breakout works flawlessly and provides stable, high-resolution measurements in lux. I used it with an ESP32 via I²C — setup was simple and the readings are consistent even under variable lighting. It’s much more accurate than basic analog photoresistors and perfect for smart lighting, environmental monitoring, or IoT automation projects. The breakout board is compact and well-soldered, making integration quick and reliable. Great value for anyone looking for precise digital light sensing in their projects.
Mar 10, 2024
Very good sensor - works good for me
