8 Channel Relay Module (USB-RLY16L, Low Power Version, Up to 16Amp)
$83.00
SKU: DFR0173
USB-powered module with eight relays, each rated 16A. Relays are SPCO type with latching state retention. Includes LED indicators for relay positions.
Purchase this product and earn 830 reward points, which are tied to VIP membership program. Learn More >
A low power version of the USB-RLY16 module, the USB-RLY16L is powered solely from the USB bus and provides eight volt free contact relay outputs with a current rating of up to 16Amp each.  The relays are SPCO (Single Pole Change Over) types and provide position 0, position 1 and common pins (latching relays and have no "normally open" or "normally closed" contacts) on the screw terminals labeled as 0, C and 1 accordingly. The relays will also retain their state in the absence of power.
The USB-RLY16L provides a red LED mounted immediately next to each relay to indicate whether it is in a position 1 state (LED on) or position 0 state (LED off).
  • Operating temperature: -40C to +70C
  • Contact arrangement: 1A, 1B, 1C
  • Contacr resistance: 50 mOhms (at 1A 24VDC)
  • Max. switching voltage: 277VAC
  • Max. switching current: 16A
  • Max. switching power: 5000VA
  • USB-RLY16L       x1
Only 18 Left
