Mini Bread Board Self Adhesive - Blue
$2.90
SKU: FIT0008-BE
  • $2.80 3+ items
  • $2.70 5+ items
  • $2.60 10+ items
A compact dark blue mini breadboard with 170 tie points and strong self-adhesive backing. Compatible with Arduino Proto Shield. Measures 1.8"x1.4". Ideal for electronics prototyping and maker projects.
This mini self-adhesive breadboard is a compact and practical prototyping tool built around 170 tie points arranged in a 17×5×2 grid layout. Finished in a clean dark blue color, this small breadboard is designed for makers, students, and engineers who need a space-efficient circuit prototyping surface. With strong adhesive backing pre-applied to the base and full compatibility with the Arduino Proto Shield, this breadboard integrates seamlessly into a wide range of builds.
Strong Self-Adhesive Backing for Flexible Placement
This mini breadboard features a robust self-adhesive layer on its base, allowing it to be firmly mounted onto enclosures, chassis panels, shields, or any flat surface without additional hardware. This adhesive mounting capability makes repositioning and securing the breadboard straightforward during prototyping, reducing clutter and keeping circuit layouts organized. The strong bond ensures the board stays firmly in place even during active development and repeated component insertion and removal.
Compact 170 Tie-Point Layout for Dense Prototyping
Measuring just 1.8"×1.4", this mini breadboard packs 170 tie points into an impressively small footprint, making it ideal for constrained builds where space is at a premium. The 17×5×2 point arrangement supports a wide range of small-scale circuit configurations, from sensor breakout connections to logic-level signal routing. Despite its compact size, this breadboard maintains standard 2.54mm pitch compatibility, ensuring broad support for common through-hole components and jumper wires.
From wearable electronics and compact robotics to desktop sensor modules and educational circuit experiments, this mini self-adhesive breadboard delivers reliable prototyping performance in a minimal form factor. Available in multiple colors, it suits builders who value both function and visual organization across multi-board project setups.
  • 170 tie points in a compact 17×5×2 grid layout
  • Strong self-adhesive backing for tool-free surface mounting
  • Compatible with Arduino Proto Shield
  • Compact dimensions: 1.8"×1.4"
  • Available in multiple colors for visual project organization
  • Standard 2.54mm pitch for broad component compatibility
  • Electronics circuit prototyping
  • Arduino Proto Shield expansion projects
  • Wearable electronics development
  • Compact robotics and sensor module wiring
  • Educational circuit experimentation
  • 170 tie point breadboard
  • 17 x 5 x 2 points
  • Adhesive backing
  • Dark blue
  • Dark blue 170 tie point bread board ×1
  • Mini Bread Board Self Adhesive - Blue
