2x1A DC Motor Shield for Arduino
$10.90
SKU: DRI0001
DC Motor Shield for Arduino uses the L293 chip, drives two 7-12V DC motors with 1A current per channel, supports PWM speed control, and stacks on Arduino boards.
Arduino Motor Shield based on the L293 driver chip enables straightforward control of two DC motors within hobby robotics and embedded motion projects. This dual‑channel motor driver shield operates from a 7–12V motor supply and delivers up to 1A per channel, providing reliable drive capability for small robots, wheeled platforms, and mechanical prototypes. Designed for seamless integration, the expansion board can be stacked directly onto standard development boards such as Arduino, Arduino Uno , and Arduino Mega. This motor control shield simplifies motion control hardware while maintaining compatibility with common microcontroller ecosystems.
Dual‑Channel L293 Motor Driver Architecture
Built around the widely adopted L293 H‑bridge driver, this motor control expansion board enables independent control of two DC motors using a single microcontroller platform. Each channel supports operating voltages from 7V to 12V and delivers up to 1A of current, allowing reliable bidirectional control of small motors used in robotics kits, automated mechanisms, and experimental mechanical builds. The integrated driver circuitry manages motor direction and switching internally, allowing clean separation between control logic and motor power systems.
Stackable Design for Arduino Development Boards
This robotics motor shield follows the standard Arduino shield footprint, allowing direct stacking onto compatible controller boards without additional wiring. The hardware layout aligns with common pin mappings and supports seamless installation on Arduino Uno and Arduino Mega platforms used widely in prototyping environments. Such mechanical and electrical compatibility simplifies hardware assembly, accelerates project iteration, and enables rapid deployment within robotics experiments, classroom demonstrations, and STEM development platforms.
PWM Speed Control and Dedicated Motor Pins
Motor control signals are routed through digital pins 4, 5, 6, and 7, enabling structured control over motor direction and speed. PWM capability allows adjustable motor speed through software control, supporting smooth acceleration and precise motion behavior. This PWM‑enabled driver board is suitable for wheeled robot movement, conveyor prototypes, automated mechanisms, and other systems requiring variable speed control. Clear pin assignments simplify firmware development and integration with standard motor control libraries.
Reliable DC motor control capabilities make this L293‑based Arduino motor driver shield suitable for robotics platforms, mobile vehicle prototypes, and classroom engineering experiments. The compact expansion board enables bidirectional drive and PWM speed adjustment while remaining easy to integrate with common microcontroller boards. Such characteristics support applications ranging from small autonomous vehicles and mechanical learning kits to rapid prototyping of motion systems.
  • L293 H-bridge motor driver architecture
  • Controls two DC motors independently
  • Operating motor voltage: 7–12V
  • Maximum current up to 1A per channel
  • Supports PWM speed control
  • Compatible with standard Arduino shield interface
  • Dedicated motor control pins: 4, 5, 6, and 7
  • Two‑wheel and four‑wheel robotics platforms
  • DIY robotic vehicle projects
  • Educational robotics experiments
  • Motorized mechanical prototypes
  • STEM learning and motion control demonstrations
    Basic Parameters
  • Motor Channels: 2
  • Motor Voltage Range: 7-12V
  • Maximum Current per Channel: 1A
  • Control Pins: 4, 5, 6, 7
  • Speed Control: PWM supported
  • Driver Chip: L293
  • 1A Motor Shield For Arduino x1
    DFRobot Motor Drive Expansion Board Selection Guide
    Blog DFRobot Motor Drive Expansion Board Selection Guide
    Dec 26, 2018
    Out Of Stock
