I2C LCD Backpack
$6.50
SKU: DFR0175
  • $6.37 2+ items
  • $6.18 5+ items
  • $5.85 10+ items
The I2C LCD Backpack allows easy control of compatible LCDs via an I2C bus, reducing pin usage to 2. It features adjustable contrast and supports LCD1601, LCD1602, LCD1604, and LCD2004.
Purchase this product and earn 65 reward points, which are tied to VIP membership program. Learn More >
DFRobot I2C LCD Backpack simplifies parallel LCD integration by converting traditional multi‑pin character displays into an efficient two‑wire communication interface. This compact LCD interface adapter uses the PCA8574 I2C I/O expander to control standard HD44780‑compatible displays through an I2C bus, dramatically reducing wiring complexity in embedded projects. The display interface board supports common character modules including LCD1601, LCD1602, LCD1604, and LCD2004. Through the I2C/TWI bus, microcontroller platforms such as Arduino can drive character LCDs using only SDA and SCL connections, leaving valuable GPIO resources available for sensors, actuators, and other peripherals.
I2C LCD Backpack
I2C LCD Backpack
Two‑Wire LCD Control via I2C
This LCD communication module converts conventional parallel LCD interfaces into a streamlined I2C connection using the PCA8574 I/O expander. Only two signal lines—SDA and SCL—are required for display control, significantly reducing wiring complexity compared with traditional 6–8 data and control pins. Such a design proves valuable in compact embedded systems where GPIO resources remain limited. The integrated I2C connector layout (VCC, GND, SCL, SDA) and Gadgeteer IDC10 compatibility enable convenient integration with development platforms and prototyping environments.
Broad Compatibility with Character LCD Modules
This display interface board supports multiple popular HD44780‑compatible LCD formats including LCD1601, LCD1602, LCD1604, and LCD2004. Such flexibility allows a single I2C LCD controller board to serve a wide range of display sizes and character layouts. Adjustable contrast circuitry helps ensure clear readability across different LCD panels and lighting environments. Compatibility with standard character displays makes the module suitable for embedded user interfaces, instrumentation readouts, robotics status displays, and data monitoring panels.
Additional 8‑Bit GPIO Expansion Capability
Beyond LCD control functionality, the integrated PCA8574 provides an 8‑bit quasi‑bidirectional I/O port accessible through the I2C bus. This capability allows the module to function as a compact general‑purpose I/O expansion solution in advanced embedded designs. Engineers can utilize the available I/O lines for auxiliary control signals, additional peripherals, or custom hardware interfaces while maintaining a minimal pin footprint on the host controller.
Through efficient I2C communication and broad LCD compatibility, this LCD backpack module enables clean wiring and reliable display integration across robotics, instrumentation, and embedded interface projects. The compact adapter board suits rapid prototyping environments, educational electronics labs, and embedded control systems requiring simple character‑based visual feedback.
  • Converts parallel LCD interface to I2C communication
  • Based on PCA8574 8‑bit I/O expander
  • Reduces LCD control to only two signal lines (SDA, SCL)
  • Adjustable LCD contrast
  • Compatible with LCD1601, LCD1602, LCD1604, and LCD2004 modules
  • Supports Gadgeteer IDC10 interface
  • Provides 8‑bit quasi‑bidirectional GPIO expansion
  • Character LCD interfaces for embedded systems
  • Robotics status display panels
  • Data monitoring and instrumentation readouts
  • Compact microcontroller projects with limited GPIO
  • STEM electronics prototyping and educational projects
    Basic Parameters
  • I2C Address: 0x20-0x27(0x20 default)
  • Adjustable contrast
  • Supply voltage: 5V
  • Interface: I2C/TWI x1, Gadgeteer interface x2
  • 8-bit quasi-bidirectional port
  • LCDs supported: LCD1601,LCD1602,LCD1604,LCD2004
  • Physical Dimensions
  • Size:40x20x10mm, 58x20x10mm(2.28x1.18x0.39")
  • I2C LCD Backpack x1
  • I2C LCD Backpack
