Gravity: Mini Touch Kit
$6.90
SKU: SEN0104
The touch sensor connects to Arduino's IO shield and works on surfaces like metal, glass, and plastic. It requires basic soldering and offers a sticky metallic tape.
DFRobot Mini Touch Sensor provides a simple way to create hidden, responsive controls in interactive electronics. This compact capacitive touch module detects finger contact through conductive surfaces and converts physical touch into a digital signal suitable for microcontroller input. The small PCB connects easily to common development platforms and supports rapid integration into embedded prototypes. Combined with an adhesive copper pad, this touch-sensitive input module enables discreet switch placement behind panels, glass, or metal surfaces, delivering an elegant alternative to traditional mechanical buttons in interactive installations, robotics interfaces, and smart object designs.
Invisible Button Design with Adhesive Copper Pad
An included copper sensing pad with adhesive backing enables flexible sensor placement across enclosures and surfaces. This capacitive touch interface can be mounted behind panels or integrated directly into product housings to create invisible touch buttons. The conductive copper plate extends the sensing area, allowing the touch detection circuit to remain hidden inside a project while maintaining reliable trigger response. Such flexibility makes the touch sensing module particularly suitable for custom control panels, interactive exhibits, and minimalist device designs where mechanical switches would disrupt appearance.
Reliable Capacitive Detection Across Multiple Materials
This digital touch detection board senses human contact through various non‑conductive or conductive materials. Stable detection performance is achieved on surfaces including metal, glass, plastic, and rubber, enabling integration into diverse project enclosures. Such versatility supports embedded electronics that require sealed or protected interfaces. Designers can integrate the sensor beneath protective layers or decorative panels while still capturing finger interaction, making the capacitive sensing module effective for appliances, experimental prototypes, and creative electronics installations.
Simple Digital Output for Microcontroller Integration
The touch sensing circuit outputs a digital signal that can be read directly by common development platforms such as Arduino. Straightforward wiring and a compact footprint allow this interactive input module to integrate easily with IO expansion shields and embedded control boards. Basic soldering connections provide reliable electrical contacts while maintaining minimal hardware complexity, making the digital touch module suitable for rapid prototyping, experimental electronics, and classroom demonstrations.
Compact size, flexible mounting, and digital output make this capacitive touch module useful in numerous interactive electronics scenarios. Typical implementations include hidden control buttons, smart home interfaces, robotics control panels, and creative installations within STEM Education environments. The sensor board also supports rapid prototyping of touch‑activated lighting, interactive displays, and embedded user interfaces that benefit from seamless surface interaction.
  • Capacitive touch sensing for hidden button interfaces
  • Adhesive copper pad enables flexible sensor placement
  • Digital output signal compatible with common microcontrollers
  • Works through surfaces such as metal, glass, plastic, and rubber
  • Compact PCB suitable for embedded electronics projects
  • Supports interactive prototypes and touch‑activated controls
  • Hidden touch buttons in electronic enclosures
  • Interactive installations and exhibits
  • Robotics control interfaces
  • Smart home touch panels
  • STEM Education interactive electronics projects
    Basic Parameters
  • Power supply: 3.3-5v
  • Dimension: 15 * 10 mm/0.6 * 0.39 inches
  • Pin definition: Digital output(Green wire) Power(Red wire) GND(Black wire)
  • ITA-Touch module with Digital sensor cable x1
  • 3x3cm copper with the sticky part x1
  • 15cm wire x1
  • FAQ
    Andrew.Wickens Jan 24, 2026
    Fun and easy touch input kit for projects. Simple to set up and works well with Arduino and other microcontrollers. The touch response is reliable and it’s great for learning or adding basic touch interaction to small projects. Good quality parts and clear documentation.
