Gravity: Mini Touch Kit
$6.90
SKU: SEN0104
The touch sensor connects to Arduino's IO shield and works on surfaces like metal, glass, and plastic. It requires basic soldering and offers a sticky metallic tape.
This is a cool touch sensor from DFRobot. You can hook it up to the IO Expansion shield (for arduino) directly. It includes a metallic tape with a sticky side. This make it possible for you to place your sensors anywhere you want. So, if you get sick of the typical push buttons, try this invisible button for your projects! This touch sensor works on a variety of surfaces; Metal, glass, plastic, rubber. It does not work on cardboard or wood.
NOTE:This sensor requires some basic soldering.
  • Power supply: 3.3-5v
  • Dimension: 15 * 10 mm/0.6 * 0.39 inches
  • Pin definition:
    • Digital output(Green wire)
    • Power(Red wire)
    • GND(Black wire)
  • ITA-Touch module with Digital sensor cable   x1
  • 3x3cm copper with the sticky part   x1
  • 15cm wire   x1
Andrew.Wickens Jan 24, 2026
Fun and easy touch input kit for projects. Simple to set up and works well with Arduino and other microcontrollers. The touch response is reliable and it’s great for learning or adding basic touch interaction to small projects. Good quality parts and clear documentation.
