_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
Simple, Reliable Switching for High-Power Devices.The Gravity: Digital Relay Module provides safe and stable ON/OFF control for high-power AC and DC loads through a standard low-voltage digital signal. It is widely used in automation systems, Arduino-based projects, smart home devices, and industrial prototypes.
Designed for plug-and-play integration, the module eliminates the need for external driver circuits while offering clear status feedback through a built-in indicator LED.
Features of Gravity: Digital Relay Module
Operating Principle
The relay functions as an electrically controlled mechanical switch. A low-power digital signal activates an internal electromagnetic coil, which mechanically opens or closes the high-power circuit.
Switching is suitable for low-frequency control applications such as ON/OFF automation.
Quick Start (Arduino Example)
A standard Arduino setup enables relay toggling within minutes using a digital output pin.
Wiring Overview
Behavior
The relay switches ON and OFF every 2 seconds, demonstrating basic functional control and system responsiveness.
Compatibility Notes
Important Usage Guidance
This relay module is optimized for simple, reliable switching tasks where electrical isolation and safe high-voltage control are required. It serves as a fundamental building block in embedded control systems and automation projects.
Jan 22, 2025
Easy to connect - does what it's supposed to - perfect for my DIY projects. Never had any problems with it so far.
Jul 13, 2022
Great relay module for controlling devices through my Arduino projects, such as routing power, and supplying power greater than the 5vdc used with Arduino.
Aug 23, 2021
