Gravity: Nano I/O Shield for Arduino Nano
$6.90
SKU: DFR0012
The Arduino Nano I/O Sensor Shield is an expansion board compatible with various microcontrollers, offering multiple power input options and easy sensor connections.
The Arduino Nano I/O  Sensor Shield acts as an expansion board for the Arduino Nano and DFRduino Nano microcontrollers. There are several different options for power input. The form factor of the Nano I/O Shield board is the same as the Arduino UNO/arduino Leonardo. In addition, the sensor shield adopts Gravity interface that each pinout includes 5V and GND pins for easy connection to Gravity sensors or servos. To the best compatibility, the shield supports jumper wires for rapid prototyping.
This unit comes fully assembled. The board also has a space specifically for the DFRobot bluetooth module and ACP220. Several I2C pins are also expanded.
The arduino nano shield has independent power supply to provide extra power for servo and other sensors.
V1.1 Update:Add a I2C interface switch, now it is compatible with Arduino Nano, DFRduino Nano V4 and Bluno Nano
Compatible Microcontrollers
  • Arduino Nano
  • DFRduino Nano V3
  • Dreamer Nano V4.1
  • Bluno Nano
    Any Nano microcontroller which have the same pinout as Arduino Nano
    • Power supply: +5 V
    • Size: 69x54mm (2.7 x 2.1 in)
    • Nano I/O Shield for Arduino Nano    x1
    Tom.Kvichak Jul 13, 2022
    This I/O Shield is the best I've used in my Arduino projects. Typical application for me is to connect my servos & relays on my model railroad
