Waterproof DS18B20 Digital Temperature Sensor for Arduino (IP68, -10°C to +85°C)
$6.90
SKU: DFR0198
  • $6.70 5+ items
  • $6.20 10+ items
  • $5.50 50+ items
Waterproof digital temperature sensor with a range of -55°C to 125°C. Connects via 1-Wire interface, suitable for humid environments and supports multiple sensors.
This product is the waterproof version of the DS18B20 temperature sensor, specifically designed for temperature measurements in distant or humid environments. This temperature & humidity sensor has a wide temperature range of -55°C to 125°C, but it is recommended to keep the included PVC jacketed cable below 100°C to ensure optimal performance and durability.
The DS18B20 waterproof temperature sensor is a digital sensor that maintains signal integrity even over long distances. It utilizes a 1-Wire interface, connecting to a central microprocessor through a single wire (along with a ground wire).
Note: This sensor includes the probe with bare wires only. For a solderless connection with a pluggable terminal adapter, please check the Gravity: Waterproof DS18B20 Sensor Kit.
Each DS18B20 temperature sensor has a unique silicon serial number, useful for verifying its authenticity and enabling the connection of multiple sensors on a single 1-Wire bus. This feature facilitates the installation of temperature sensors in various locations for applications like indoor temperature monitoring, smart home integration, object temperature detection, greenhouse farming, and more.
  • Usable with 3.0V to 5.5V power/data
  • ±0.5°C Accuracy from -10°C to +85°C
  • Usable temperature range: -55 to 125°C (-67°F to +257°F)
  • 9 to 12 bit selectable resolution
  • Uses 1-Wire interface- requires only one digital pin for communication
  • Unique 64 bit ID burned into the chip
  • Multiple sensors can share one pin
  • Temperature-limit alarm system
  • Query time is less than 750ms
  • 3 wires interface:
    • Type A
      • Red wire - VCC
      • Black wire - GND
      • Yellow wire - DATA
    • Type B (Recently there's a series of sensors using this pin mapping. Sorry for the inconvenience.)
      • Red wire  - VCC
      • Yellow wire - GND
      • Green wire - DATA
  • Stainless steel tube 6mm diameter by 35mm long
  • Cable diameter: 4mm (0.16)
  • Length: 95cm (37.4")
  • Waterproof DS18B20 Digital temperature sensor x1
(Note: Terminal adapter not included. Please solder a 4.7k resistor between VCC and Data for usage, or choose the Gravity Kit version for plug-and-play.)
IoT AI-driven Yogurt Processing & Texture Prediction w/ Blynk
Projects IoT AI-driven Yogurt Processing & Texture Prediction w/ Blynk
Kutluhan Aktar
Jun 09, 2025
Make a TDS Detector for Water Testing Experiment
Projects Make a TDS Detector for Water Testing Experiment
Frances
Sep 15, 2022
Muhammad Fadil.Huseiny Nov 05, 2025
Good working stable as intended
Muhammad Fadil.Huseiny Oct 30, 2025
Really Good, product working well
wajdi. Oct 21, 2022
Very good as description
