MQ7 Carbon Monoxide Sensor (20-2000ppm Detection, Analog Output)
$2.00
SKU: FIT0227
A CO sensor detecting 20-2000ppm with a simple drive circuit. Requires 5V power, a load resistance, and ADC connection. Includes a datasheet and wiring guide.
Purchase this product and earn 20 reward points, which are tied to VIP membership program. Learn More >
The MQ7 Carbon Monoxide Sensor provides reliable 20-2000ppm CO detection with analog resistance output, simplifying integration into Arduino and Raspberry Pi projects. Ideal for air quality monitors, industrial safety systems, and smart home automation.
Wide Detection Range for Versatile Use
Accurately measures CO concentrations from 20 to 2000ppm, suitable for indoor air quality and industrial leak detection.
Analog Output for Easy Integration
Simple voltage divider circuit connects directly to ADC pins on microcontrollers like Arduino UNO or ESP32.
Low Power & Stable Performance
5V heater coil ensures consistent sensitivity, while minimal power draw (≈150mA) suits battery-powered devices.
No Calibration Required
Pre-calibrated for plug-and-play operation, reducing setup time for DIY projects and prototyping.
  • Detection Range 20-2000ppm CO
  • Output Analog resistance (0-5V)
  • Power Supply 5V DC (heater coil)
  • Heater Current ≈150mA (typical)
  • Operating Temp -10°C to 50°C
  • Carbon Monoxide Sensor (MQ7) x1
  • MQ7 Carbon Monoxide Sensor (20-2000ppm Detection, Analog Output)
