Gravity: Steam Sensor
$1.99
SKU: SEN0121
  • $1.95 2+ items
  • $1.85 5+ items
  • $1.75 10+ items
Steam sensor connects to Arduino IO shield, increases output voltage with surface humidity. Not waterproof. Applications: rain detector, steam switch, touch sensor.
Purchase this product and earn 20 reward points, which are tied to VIP membership program. Learn More >
This is a steam(water)sensor from DFRobot. This steam sensor can be connected to the Arduino IO Expansion shield directly. The output voltage will increase when the humidity of the sensor surface goes up.
Notice:The new version of analog sensor port pin mapping has been changed as the following two features.
Warning: The connector is not waterproof, please be careful not to put the connector directly in water.
  • Simple rain detector
  • Cheap steam level switch
  • Touch sensor based on humidity
  • Power supply: 3.3v or 5v
  • Output voltage signal: 0~4.5v(@5v) or 0~3.0v(@3.3v)
  • Pin definition:
  • Analog output(Blue wire)
  • GND(Black wire)
  • Power(Red wire)
  • Size: 30x20x6mm (0.18x0.79x0.24")
  • Steam sensor    x1
  • Analog Sensor Cable    x1
Only 1 Left
