DFRduino UNO R3 - Compatible with Arduino Uno
$12.90
SKU: DFR0216
A compact microcontroller board compatible with Arduino IDE, featuring color-coded headers for easy sensor connectivity, ideal for academic and development use.
DFRduino Uno V3.0 from DFRobot is a physical world computing board of small size for academics or development . It is a simple microcontroller board fully compatible with Arduino UNO R3 and Arduino IDE open-source development environment. This environment implements the Processing / Wiring language. Arduino can be used to develop stand-alone interactive objects or can be connected to software on your computer (e.g. Flash, Processing, MaxMSP). The open-source IDE can be downloaded for free (currently for Mac OS X, Windows, and Linux).
This board features the ATmega16U2 programmed as a USB-to-serial converter. An added bonus is that our DFRduino is still using the DIP package AVR Chip. You could remove it to update or reprogram the chip's firmware, or even to place it on a finished, more compact project. The cool thing about our new DFRduino microcontroller is that the headers use different colors to feature I/O ports of different types:
  • Red for Power Section.
  • Blue for Analog I/O.
  • Green for Digital I/O.
These colors match our sensor cables. This makes it really easy to figure out where to connect sensors, or to identify which side is Analog (blue) or Digital (green).
"Arduino Uno" is a microcontroller board based on the ATmega328. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started.
This board added SDA and SCL pins that are near to the AREF pin and two other new pins placed near to the RESET pin, the IOREF that allow the shields to adapt to the voltage provided from the board. In future, shields will be compatible both with the board that use the AVR, which operate with 5V and with the "Arduino Due" that operate with 3.3V. The second one is a not connected pin, that is reserved for future purposes.
  • Microcontroller: ATmega328 (DIP package)
  • Operating voltage: 5V
  • Input voltage: No external power supply needed when connected to USB or external 7V~12V DC input
  • Output voltage: 5V DC output and 3.3V DC output
  • Clock speed: 16 MHz
  • Bootloader: Arduino Uno
  • Supports USB interface protocol and power supply (no external power source needed)
  • Supports ISP download function
  • Digital I/O pins: 14 (6 are PWM outputs)
  • Analog input pins: 6
  • DC current per I/O Pin: 40mA
  • DC current for 3.3V Pin: 50mA
  • Flash memory: 32 KB (ATmega328)
  • SRAM: 2 KB (ATmega328)
  • EEPROM: 1 KB (ATmega328)
  • Dimensions: 75 x 54 x 15 mm (2.95 x 2.13 x 0.59 inches)
  • Environmental Friendly: Complies with Rohs standards
    • DFRduino Uno V3.0  x1
    Use Your Hand as the Controller — Experience a New Way to Play Angry Birds with HUSKYLENS 2
    Projects Use Your Hand as the Controller — Experience a New Way to Play Angry Birds with HUSKYLENS 2
    auroraAA
    Oct 31, 2025
    How To Build a Real Steel Robot? Lesson 4
    Blog How To Build a Real Steel Robot? Lesson 4
    Jun 28, 2017
    How to Build a Robot – Lesson 1: Introduction
    Blog How to Build a Robot – Lesson 1: Introduction
    Nov 12, 2016
    Existential Crisis aka Arduino RPG
    Blog Existential Crisis aka Arduino RPG
    Aug 30, 2016
    LattePanda Project: C# Arduino GUI to control the LED
    Blog LattePanda Project: C# Arduino GUI to control the LED
    Apr 03, 2018
    DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Blog DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Jul 30, 2020
    Dave.Kriedeman Feb 20, 2021
    Simon.Holden Aug 27, 2025
    Solid build quality, color-coded pins helpful. Easy to use, shipping was impressively fast.
    Perfect for beginners, works exactly like original Arduino. Fast delivery, very satisfied.
