Gravity: Digital Buzzer for Arduino / ESP32 / micro:bit / Raspberry Pi
$1.90
SKU: DFR0032
  • $1.80 3+ items
  • $1.70 5+ items
  • $1.60 10+ items
A digital buzzer module generates sounds by varying oscillation frequency. It supports 3.3V-5V and is compatible with Arduino, micro:bit, ESP32, and Raspberry Pi.
Purchase this product and earn 19 reward points, which are tied to VIP membership program. Learn More >
This digital buzzer module is a basic breath sound generator that can be driven using a high or low signal. By varying the oscillation frequency, you can hear different sounds. It finds wide application in everyday devices such as personal computers, refrigerators, and mobile phones. With this compact, useful buzzer module, you can also create a variety of intriguing interactive projects.
To simplify the use of this Arduino buzzer module, a Gravity interface is adapted to allow plug&play. The IO expansion shield is the best match for this sound sensor connected to your Arduino. As this sensor can work at 3.3V which makes it compatible with common controllers such as Arduino, micro:bit, ESP32 and Raspberry Pi.
If you are a beginner, it is recommended to purchase an Arduino kit with tutorials, such as the Gravity: Intermediate Kit for Arduino and the Gravity: Starter Kit for Arduino.
features
  • Passive buzzer generates sound based on the frequency of the input signal
  • Standard assembling structure (two 3mm holes with multiple of 5cm as interval)
  • Icons to simply illustrate sensor function
  • High quality connector
  • Immersion gold surface
  • Type: Digital
  • Power supply: 5VDC
A Seat to Save Your Cervical Vertebra
Blog A Seat to Save Your Cervical Vertebra
Apr 26, 2016
Make Sports Push Buttons with ESP32-C3 to Get You Moving
Projects Make Sports Push Buttons with ESP32-C3 to Get You Moving
Frances
Mar 02, 2023
Arduino Alarm Clock using DS1307
Projects Arduino Alarm Clock using DS1307
Jainesh.Rathod
Feb 22, 2023
Frances
Oct 25, 2021
Michael.Samyn Apr 02, 2026
Very nice product and very nice quality.
