Sharp GP2Y1010AU0F Optical Dust Sensor - PM2.5/PM10 Detection
$11.50
SKU: SEN0144
  • $11.40 2+ items
  • $11.20 5+ items
  • $10.80 10+ items
The optical dust sensor detects air particles using infrared light and a phototransistor. It's ideal for air purifiers and environmental monitoring systems.
Purchase this product and earn 115 reward points, which are tied to VIP membership program. Learn More >
The Sharp GP2Y1010AU0F optical dust sensor provides reliable detection of airborne particulates using infrared diode technology - essential for air quality monitoring and purification systems.
Dual-Purpose Smoke & Dust Detection
Infrared optical system distinguishes between smoke particles (0.3-1µm) and larger dust particulates (1-10µm) through unique pulse pattern analysis.
Linear Analog Output
Generates 0.5V per 0.1mg/m³ density change (0-3.5V range) for precise PM2.5/PM10 measurement - compatible with all microcontroller ADCs.
Compact Industrial Design
Rugged 59×45×22mm housing withstands -10°C to 65°C environments while maintaining stable readings in high-humidity conditions.
Low-Power Operation
Consumes only 11mA (20mA max) during continuous monitoring - ideal for battery-powered air quality stations.
  • Pre-calibrated for immediate use
  • Standard 3-pin Gravity compatible output
  • Compatible with Arduino/Raspberry Pi
  • Works with Gravity Dust Sensor Adapter
  • Stable performance in 30-90% RH environments
  • Smart air purifier control systems
  • Workplace air quality compliance
  • Industrial dust level monitoring
  • HVAC filter performance tracking
  • School/office environmental dashboards
  • Supply Voltage: 5-7V DC
  • Current Draw: 11mA typical (20mA max)
  • Output Signal: Analog voltage (0-3.5V)
  • Sensitivity: 0.5V per 0.1mg/m³
  • Detection Range: 0.1-0.5mg/m³ optimal
  • Operating Temp: -10°C to +65°C
  • Response Time: <10ms
  • Dimensions: 59×45×22mm
  • Optional Parts
  • Sharp GP2Y1010AU0F Dust Sensor   x1
  • Cable   x1
    Out Of Stock
