Gravity: Analog Voltage Divider V2
$3.70
SKU: DFR0051
  • $3.40 5+ items
  • $3.10 10+ items
The module detects supply voltage from 0.0245V to 25V using a resistor divider, reducing input voltage 5 times for Arduino compatibility.
Purchase this product and earn 37 reward points, which are tied to VIP membership program. Learn More >
The Analog Voltage Divider V2 can detect the supply voltage from 0.0245V to 25V. This module is based on resistor divider principle. The voltage detection module allows the input voltage to reduce 5 times. As the Arduino analog input voltage is normally maximum 5V, the input voltage of analog voltage detection module can not exceed 5Vx5 which is 25V.
Notice: The new version of analog sensor port pin mapping has been changed as the following two features.
  Inprovement List
  • Standard assembling struct (two 3mm holes with multiple of 5cm as interval)
  • High quality connector
  • Immersion gold surface
  • Interface: Analog
  • Input voltage (DC): Maximum 25V, Minimum 0.0245V
  • Detects the supply voltage upto 25V
  • Size:22x30mm (0.87x 1.18 in)
jonathan.juarez Dec 08, 2025
Worked perfectly, will continue to use these.
