SELECTION GUIDE micro:bit
DFRobot micro:bit Expansion Board Selection Guide
DFRobot Dec 24 2018 260909
Product Name
micro:bit - an Educational & Creative Tool for Kids (Discontinued)
micro:Mate - a Mini & Thin Expansion Board for micro:bit (Gravity Compatible)
micro:bit Expansion Board for Boson (Gravity Compatible)
Figure
SKU
DFR0497
DFR0518
DFR0521
Operating Voltage
3.5~5.5V
3.3V/5V
3.3V
Power supply
DC2.1/Terminals
USB
USB
External supply voltage
3.5~5.5V
3.3V/5V
3.3V/5V
Digital ports (IO/PWM)
17/8
3
3
Analog ports (input/output)
P0、P1、P2
3
3
UART
x
x
x
I2C
2
x
x
SPI
x
x
x
Interrupt pin (quantity)
x
x
x
Interface Type
Gravity
Gravity
Gravity
3.5mm headphone port
x
Dimension
63 x 58 mm
68.5×53.3 mm
80×70 mm
Mounting hole
50*55
Weight (g)
64
23
48
Drive the servo
x
Scenarios
Many motors and sensors needed
Suitable for small Works
Initial Stage
Key Features
17 io ports with 2 i2c interfaces Can drive Quad DC Motor Driver
IO port expands 6 and the pin replaces the edge connector slot Anti-reverse pad on the back, which protects the control board and prevents micro-reverseDrive high current equipment, such as steering gear, components connected to 8 12 16
3-Pin fool-proof connector x 6 Edge Connector Compatible with sensor Compatible sensor list Gravity: Digital PIR (Motion) Sensor For Arduino Gravity: Digital Capacitive Touch Sensor For Arduino Gravity:Analog Rotation Potentiometer Sensor V1 For Arduino Gravity:Analog Grayscale Sensor For Arduino Gravity: Analog Sound Sensor For Arduino Gravity: Joystick Module V2 Gravity: Analog Slide Position (Potentiometer) Sensor For Arduino Gravity: Analog AC Current Sensor Gravity: Heart Rate Monitor Sensor for Arduino Gravity: Digital Speaker Module
Add to Cart
Add to Cart
Add to Cart
Add to Cart
