SELECTION GUIDE Raspberry Pi
Raspberry Pi Board Selection Guide
DFRobot Sep 18 2019 261050
Since the advent of Raspberry Pi, its powerful functions have been catching the eye of numerous IT fans and makers. It is small, but fully equipped with all functions including video, audio, etc. What’s more, the greatly improved Raspberry Pi 4 launched in this year undoubtedly marks a big step up from the earlier models. With so many models of Raspberry Pi on the market, how to find the one just fitting your project? Thus, DFRobot provides this Raspberry Pi selection guide for you! Hope it helps.
Product Introduction:
Raspberry Pi 4 Module B
Raspberry Pi, Raspberry Pi 4, Raspberry Pi 4 Module B
Compared to the prior-generation Raspberry Pi 3 Model B+, Pi 4B offers significantly increases in processor speed, multimedia performance, memory, and connectivity.
Features Included:
(1). For the end user, Raspberry Pi 4 Model B provides desktop performance comparable to entry-level x86 PC systems, which could let you enjoy smooth and high-quality experience!
(2). Raspberry Pi 4B includes a high-performance 64-bit quad-core processor, and features dual-display support at resolutions up to 4K via a pair of micro-HDMI ports, hardware video decode at up to 4Kp60.
(3). Up to 4GB of RAM(1GB, 2GB, 4GB)
(4). Dual-band 2.4/5.0 GHz wireless LAN, Bluetooth 5.0, Gigabit Ethernet
(5). USB 2.0/3.0, and PoE capability (via a separate PoE HAT add-on)
Raspberry Pi 4B supports three kinds of RAM: 1GB, 2GB, and 4GB, but how to choose a suitable one. Here are some suggestions:
(1). 1GB will be surely enough if there is no need to use graphical user interface or to run a large number of applications, such as robot controlling, and smart DIY car.
(2). 2GB is suitable for users who want to configure graphical user interface or self the net, for instance, use Pi as a PC to watch video, or build up a micro web server.
(3). If you want to use Pi 4B to handle more complicated multiple tasks, like play 4K video on dual-screen, the 4GB version is the right one.
Even for the version of 1GB, its algorithms performance can still reach up to 3 time of the Pi 3B+. So you just need to select the RAM according to your application.
Please note that Pi 4 adopts type-c power interface, which is different from all the previous versions.
Raspberry Pi 3 Model B+, Raspberry Pi, Raspberry Pi 3 Model B+
The Raspberry Pi 3 Model B+ boasts a 64-bit quad core processor running at 1.4GHz, dual-band 2.4GHz and 5GHz wireless LAN, Bluetooth 4.2/BLE, faster Ethernet, and PoE capability via a separate PoE HAT.
The dual-band wireless LAN comes with modular compliance certification, allowing the board to be designed into end products with significantly reduce on wireless LAN compliance testing, cost and time resources. The Raspberry Pi 3 Model B+ maintains the same mechanical footprint as both the Raspberry Pi 2 Model B and the Raspberry Pi 3 Model B.
Raspberry Pi 3 Model B, Raspberry Pi 3, Raspberry Pi
Raspberry Pi 3 B features a 1.2GHz 64-bit quad-core ARMv8 CPU with 802.11n Wireless LAN and Bluetooth 4.1. Like Raspberry Pi 2, it also has 1GB RAM,4 USB ports,40 GPIO pins, Full HDMI port and Ethernet port. The board's footprint remains the same size as the Pi 2, but with more exciting features and backwards compatibility.
Raspberry Pi 3 Model A+ (E14)
Raspberry Pi 3 Model A+ (E14), Raspberry Pi 3, Raspberry Pi
With standard A+ size, this Raspberry Pi 3 model A+ inherits most features of Raspberry Pi 3 B+. It integrates a 1.4 GHz 64-bit quad-core processor and features dual-band 2.4GHz and 5GHz wireless LAN, Bluetooth 4.2 and improved thermal management.
Compared with Pi 3B+, the new Pi 3A+ has smaller RAM and drops USB hub and Ethernet controller, which makes it able to provide a lower price as well as keep a small body. Meanwhile, it is compatible with Pi 1A+, for Pi 1A+ fans or someone who wants smaller Raspberry Pi main-board, this Pi 3 A+ would be the best choice for you!
Raspberry Pi 2 Model B, Raspberry Pi 2, Raspberry Pi
Compared to the Raspberry Pi 1, Raspberry Pi 2 B has a 900MHz quad-core ARM Cortex-A7 CPU and 1GB RAM. Besides, it is equipped with the basic functions:
Ethernet port, USB, HDMI, CSI, DSI and so on. The Raspberry Pi 2 has an identical form factor to the previous (Pi 1) Model B+ and has complete compatibility with Raspberry Pi 1.
Product Name
Raspberry Pi 4 Model B-1GB
Raspberry Pi 4 Model B-2GB
Raspberry Pi 4 Model B-4GB (E14 Version)
Raspberry Pi 3 Model B(Discontinued)
Raspberry Pi 2 Model B(Discontinued)
Figure
SKU
DFR0617
DFR0618
DFR0619
DFR0567
DFR0431
DFR0594
DFR0353
SOC
BCM2711
BCM2711
BCM2711
BCM2837
BCM2837
BCM2837
BCM2836
CPU
1.5GHz, 64 bits quad-core Cortex A-72
1.4GHz, 64bits quad-core Cortex A-53
1.2GHz, 64bits quad-core Cortex A-53
1.4GHz, 64bits quad-core ARM Cortex-A53
SD Card Slot
Micro SD
Micro SD
Micro SD
Micro SD
Micro SD
Micro SD
Micro SD
RAM
1GB
2GB
4GB
1GB
1GB
512MB
1GB
GPIO
40-pin
40-pin
40-pin
40-pin
40-pin
40-pin
40-pin
GPU
VideoCore IV
VideoCore IV
VideoCore IV
VideoCore IV
VideoCore IV
VideoCore IV
VideoCore IV
Max Resolution
4K, 60Hz
4K, 60Hz
4K, 60Hz
1080P30
R1080P30
1080P30
1080P
Video Input
Dual-lane CSI camera port
CSI camera port
CSI camera port
CSI camera port
CSI camera port
Video Output
R2 HDMI ports, dual-lane DSI port
Full-size HDMI
HDMI, DSI port
HDMI, DSI port
HDMI, DSI port
USB Port
2×USB3.0 + 2×USB2.0
2×USB3.0 + 2×USB2.0
2×USB3.0 + 2×USB2.0
4×USB2.0
4×USB2.0
1×USB2.0
4×USB2.0
Ethernet
Gigabit Ethernet
Gigabit Ethernet
Gigabit Ethernet
Gigabit Ethernet
100 Mbit Ethernet
None
100 Mbit Ethernet
Wireless Network
802.11ac(2.4/5GHz), Bluetooth 5.0
802.11b/g/n/ac(2.4/5GHz), Bluetooth 4.2
802.11n(2.4GHz) , Bluetooth 4.0
802.11ac(2.4/5GHz), Bluetooth 4.2
None
Charging Port
USB Type-C
USB Type-C
USB Type-C
micro USB
micro USB
micro USB
micro US
Power Supply
3A, 5V
3A, 5V
3A, 5V
2.5A, 5V
2.5A, 5V
2.5A, 5V
1.8A, 5V
Power Via PoE
Supported
Supported
Supported
Supported
Unsupported
Unsupported
Unsupported
Dimension
88*58*19.5mm/ 3.5*2.3*076”
82*56*19.5mm/ 3.2*2.3*0.76”
87*58*19mm/ 3.43*2.28*0.75"
65*56mm/ 2.56*2.20"
Weight
46g
46g
46g
50g
45g
45g
45g
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
