SELECTION GUIDE
Selection Guide for DFRobot pH Sensors
DFRobot Jan 13 2025 275579
Welcome to the DFRobot pH Sensor Selection Guide. Based on our current lineup of pH sensors and electrodes with varying specifications, this guide is designed to help developers, researchers, and industrial users quickly identify the most suitable model for their specific application scenarios.
Quick Selection Guide (By Application Scenario)
Detailed Product Categories & Technical Analysis
Category 1: Laboratory-grade Sensors (Suitable for short-term measurement, teaching demonstrations, and maker projects)
This series offers exceptional cost-performance and good measurement accuracy, meeting most routine testing needs. Note: Laboratory-grade probes are NOT suitable for long-term underwater continuous monitoring. After use, they must be cleaned and properly stored in a protective solution.
  • Product Advantages: Fully upgraded to a 3.3~5.5V wide voltage operating range, making it perfectly compatible with mainstream open-source hardware like Arduino, Raspberry Pi, and micro:bit. A built-in hardware filtering circuit ensures smoother and more stable signal output, while the software library supports the automatic identification of standard buffer solutions.
  • Application Scenarios: Maker DIY projects, initial hydroponic environment testing, and college/university laboratory teaching.
Category 2: Industrial-grade Online Monitoring Sensors (Suitable for aquaculture, long-term automated equipment)
Utilizing a PTFE (Polytetrafluoroethylene) ring membrane and gel electrolyte, this series boasts excellent anti-pollution and anti-clogging properties, supporting 7/24 long-term underwater submersion.
  • Product Advantages: Also upgraded with 3.3~5.5V wide voltage support and hardware filtering. Equipped with a 5-meter industrial cable, the probe features a design life of over half a year under normal water conditions.
  • Application Scenarios: Long-term water quality monitoring for aquariums and fish tanks, automated dosing systems for smart agriculture/hydroponics, and wastewater treatment process monitoring.
  • Product Advantages: Features a sharp stainless steel spear tip protection shield, allowing direct insertion into semi-solid materials like wet soil, fruits, vegetables, and meat for pH measurement.
  • Precautions: Measurement range is 0-10 pH. It is strictly prohibited from measuring hard solids or samples containing sharp particles. The probe must be carefully cleaned after each test.
Category 3: Industrial IoT / Robust Bus Communication Integration
Designed specifically for mature industrial control systems, PLC equipment, or long-distance wireless transmission nodes (such as the DFRobot LoRaWAN ecosystem).
  • Product Advantages: Adopts an integrated industrial-grade housing design, supporting RS485 interfaces and the standard Modbus-RTU protocol. It possesses strong anti-electromagnetic interference capabilities, making it ideal for long-distance transmission. A built-in temperature sensor provides Automatic Temperature Compensation (ATC). Supports a 10-30V DC wide voltage power supply and features an IP68 waterproof rating.
  • Application Scenarios: Industrial field deployment, large-scale smart agriculture IoT nodes, commercial aquaculture, and wastewater treatment plants.
Category 4: Replacement Accessories & Consumables
3. Core Parameters Comparison Table
Product Name
Gravity: Lab Grade Analog pH Sensor Kit for Arduino
Gravity: Lab Grade Analog pH Sensor Kit for Arduino / Raspberry Pi (with Calibration Solutions)
Gravity: 7/24 Industrial Analog pH Meter Kit for Arduino
Gravity: 7/24 Industrial Analog pH Meter Kit (Arduino, Raspberry Pi)
RS485 Modbus Water Quality pH Sensor (IP68)
Figure
SKU
SEN0161
SEN0161-V2
SEN0169
SEN0169-V2
SEN0708
Signal Output
Analog Voltage
Analog Voltage
Analog Voltage
Analog Voltage
Digital Comm (RS485 Modbus)
pH Range
0~14 pH
0~14 pH
0~14 pH
0~14 pH
0~14 pH
Operating Voltage
5.0V
3.3~5.5V
5.0V
3.3~5.5V
10~30V DC
Accuracy
±0.1 pH
±0.1 pH
±0.1 pH
±0.1 pH
±0.15 pH (Includes ATC)
Long-term Submersion
❌ No (Not supported)
✅ Yes (7/24 support)
✅ Yes (IP68 Waterproof)
Cable Length
~100cm
~100cm
500cm
500cm
500cm
Typical Target
Routine water sampling
Long-term monitoring of general water, weak acid/base
Complex industrial wastewater, large-scale agricultural water
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
4. Selection & Usage Precautions
To ensure the accuracy of your measurement data and prolong the sensor's lifespan, please pay attention to the following points during selection and usage:
  • Verify power supply voltage compatibility: If you are using a Raspberry Pi, ESP32, or a new-generation mainboard with 3.3V logic levels, it is highly recommended to select analog sensor models with the "V2" designation. They feature built-in wide-voltage regulator chips, perfectly supporting 3.3V power supplies and signal outputs without additional level shifters.
  • Regarding white crystals around the probe cap: Upon receiving a new probe, you may notice a small amount of white powder crystallization around the protection cap. This is a normal physical phenomenon caused by the minor leakage and subsequent drying of the internal 3.3mol/L KCl protective solution during transit. It does not affect the lifespan or accuracy of the probe. Simply brush the crystals back into the cap, or add a suitable amount of pure water/KCl solution to keep the probe moist, and use it with confidence.
  • The importance of temperature compensation: The pH value of a solution fluctuates with temperature. In high-end applications, the RS485 Modbus Water Quality pH Sensor (SEN0708) comes with built-in Automatic Temperature Compensation (ATC). For other analog models, if the water temperature in your measurement environment fluctuates significantly, it is highly recommended to add a dedicated water temperature sensor (such as the DS18B20) to your system and incorporate temperature compensation logic into your software algorithm to obtain more rigorous pH measurements.
