Welcome to the DFRobot pH Sensor Selection Guide. Based on our current lineup of pH sensors and electrodes with varying specifications, this guide is designed to help developers, researchers, and industrial users quickly identify the most suitable model for their specific application scenarios.
This series offers exceptional cost-performance and good measurement accuracy, meeting most routine testing needs. Note: Laboratory-grade probes are NOT suitable for long-term underwater continuous monitoring. After use, they must be cleaned and properly stored in a protective solution.
Gravity: Lab Grade Analog pH Sensor Kit for Arduino / Raspberry Pi (with Calibration Solutions)
SKU: SEN0161-V2
Utilizing a PTFE (Polytetrafluoroethylene) ring membrane and gel electrolyte, this series boasts excellent anti-pollution and anti-clogging properties, supporting 7/24 long-term underwater submersion.
Gravity: 7/24 Industrial Analog pH Meter Kit (Arduino, Raspberry Pi)
SKU: SEN0169-V2
Designed specifically for mature industrial control systems, PLC equipment, or long-distance wireless transmission nodes (such as the DFRobot LoRaWAN ecosystem).
Product Name
Figure
SKU
SEN0161
SEN0161-V2
SEN0169
SEN0169-V2
SEN0708
Signal Output
Analog Voltage
Analog Voltage
Analog Voltage
Analog Voltage
Digital Comm (RS485 Modbus)
pH Range
0~14 pH
0~14 pH
0~14 pH
0~14 pH
0~14 pH
Operating Voltage
5.0V
3.3~5.5V
5.0V
3.3~5.5V
10~30V DC
Accuracy
±0.1 pH
±0.1 pH
±0.1 pH
±0.1 pH
±0.15 pH (Includes ATC)
Long-term Submersion
❌ No (Not supported)
✅ Yes (7/24 support)
✅ Yes (IP68 Waterproof)
Cable Length
~100cm
~100cm
500cm
500cm
500cm
Typical Target
Routine water sampling
Long-term monitoring of general water, weak acid/base
Complex industrial wastewater, large-scale agricultural water
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
To ensure the accuracy of your measurement data and prolong the sensor's lifespan, please pay attention to the following points during selection and usage:
