#include <AFMotor.h>
AF_DCMotor motor2(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
AF_DCMotor motor1(1, MOTOR12_64KHZ);
int state = 0;
void setup() <br>{
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Welcome: Forward = 1 Left = 2 Right = 3 Backwards = 4 Stop = 0");
motor2.setSpeed(200); // set the speed to 200
motor1.setSpeed(200); // set the speed to 200
void loop(){ //if some data is sent, read it and save it in the state variable
if(Serial.available() > 0)
state = Serial.read();
Serial.print("I received: ");
Serial.println(state);
delay(10);</p>
if (state == '0')
motor2.setSpeed(200); // set the speed to 200/255
motor1.setSpeed(200); // set the speed to 200/255
motor2.run(RELEASE); // turn it on going forward
motor1.run(RELEASE); // turn it on going forward
Serial.println("Stopped");
delay(100);
state = 0;
else if (state == '1') // If 1 Forwards
motor2.run(FORWARD); // turn it on going forward
motor1.run(FORWARD); // turn it on going forward
Serial.println("Forward");
delay(100);
state = 0;
else if (state == '2') // If 2 Turn Left
motor1.setSpeed(255); // set the speed to 200/255
//motor2.run(BACKWARD);
Serial.println("Left");
delay(100);
state = 0;
else if (state == '3') { // If 3 Turn Right
motor2.setSpeed(255); // set the speed to 255
//motor1.run(BACKWARD);
Serial.println("Right");
delay(100);
state = 0;
else if (state == '4') // If 4 Backwards
motor2.run(BACKWARD); // Motor 2 backwards
motor1.run(BACKWARD); // Motor 1 backwards
Serial.println("Backward");
delay(100);
state = 0;
else if (state == '5')
motor2.run(RELEASE); // turn it on going release
motor1.run(RELEASE); // turn it on going release
motor1.setSpeed(140); // set the speed to 140
motor2.run(FORWARD); // Motor 2 forward
motor1.run(FORWARD); // Motor 1 forward
Serial.println("Forward Right");
delay(100);
state = 0;
else if (state == '6')
motor1.setSpeed(255); // set the speed to 255
motor2.setSpeed(140); // set the speed to 140
Serial.println("Forward Left");
delay(100);
state = 0;
else if (state == '7') // If 4 Backwards
Serial.println("Backward Right");
delay(100);
state = 0;
else if (state == '8') // If 4 Backwards
Serial.println("Backward Left");
delay(100);
state = 0;
else if (state >= '9')
Serial.println("Invalid");
delay(100);
state = 0;
<br>
