PROJECTS micro:bit
micro:bit Light(Mood Lamp)
DFRobot Feb 08 2018 262314
This content is created by Mark Ng
I have the privilege of using this new Gravity expansion board for microbit from DFROBOT. It is a very compact board and it sits nicely onto a micro:bit board. It has 6 I/O ports and a selector switch for 3V and 5V. After programming the micro:bit, you can plug in power to Vin. The Vin will power the micro:bit.
Mouted with micro:bit behind.
Comparison between my old breakout board and Gravity’s new Expansion board (on the right)
How it works?
The neopixel is connected to one micro:bit via the breakout board in P0 (Gravity expansion board). The other micro:bit acts as a remote control. The 2 micro:bits are connected via radio. When we press the A button at the remote control, a number 1 is sent to the remote micro:bit. The micro:bit will display rainbow colors.
Remote ControlNeopixel Display
ARainbow colors
BPurple
A+BTurn off
Hacking the lamp
1. Remove the cable connected to the bulb connector and drill a hole through the bulb connector.
2. Insert the neopixel through the bulb connector hole.
Top
Bottom of lamp
3. Connections:
NeopixelGravity Expansion
GroundP0 GND(BLACK)
5VP0 3V(RED)
SignalP0(BLUE)
4. Program
micro:bit remote control
Micro:bit Neopixel
