DFRobot Forum Logo
HOME COMMUNITY FORUM WIKI BLOG LEARN
Tags FAQSuggestionsHow to selectTroubleshootingGeneral UNIHIKER3D PrintinguPyCraft Bluno PCB ServicesTelematics Mind+Easy IoT RoboticsFirebeetle ESP32/8266HUSKYLENSRaspberry PiGravityLattePandaArduino
Serial errors 103/104: Stop bit timing issues - fix? TEL0051FAQSEO FAQAftersales FAQ
userHead JaneYu 2026-02-14 08:57:29
Serial warns 'Normal power down' & LEDs off after reconnect TEL0051FAQSEO FAQAftersales FAQ
GSM USB mode: Ctrl+Z sends entire screen content TEL0051FAQSEO FAQAftersales FAQ
If the module is not working properly, plz check TEL0051FAQSEO FAQAftersales FAQ
What's the minutes and seconds of coordinate data? TEL0051FAQSEO FAQAftersales FAQ
Can this module support FTP, if yes, how? TEL0051FAQSEO FAQAftersales FAQ
Shield LEDs turn off when serial connects - 'normal power off' response TEL0051FAQSEO FAQAftersales FAQ
Leonardo GPS AT commands: Serial vs Serial1 adaptation? TEL0051FAQSEO FAQAftersales FAQ
Why do both Stat and Net LED turn off and why does it display "normal power off" on rare connections? TEL0051FAQAftersales FAQ
userHead Yx 2024-07-12 15:04:05
How to drive the module via USB port (AT command) using Leonardo after changing Serial to Serial1? TEL0051FAQAftersales FAQ
  • 1 DfPlayer recommended speaker impedance?
  • 2 New to DFPlayer (detect when audio clip has finished playing & loud pop upon power on/down)
  • 3 Beetle ESP32 C3 USB connection issue
  • 4 2-Channel I2C 0-10V DAC Module DFR0971 ESPHome integration
  • 5 EC Voltage is not stable
  • 6 DFPlayer Mini Logic Levels
  • 7 Capacitive Soil Moisture Sensor V.2
  • 8 How to Install Multiple Python Versions on Unihiker in the Simplest Way? For example , Python 3.10.
  • 9 Offline Voice recognition SEN0539
  • 10 How to use Azure Speech Recognition and Speech Synthesis
logo
Information
  • About Us
  • Warranty
  • Terms & Conditions
  • Shipping
  • Payment
  • FAQ
Customer Service
  • DFRobot Distributors
  • Contact us
  • Site Map
My Account
  • Affiliates
  • Specials
  • Coupon
