Is it compatible with UNO? DFR0850FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:24 631 Views
Pin Output and Pull-up FAQDFR0652SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:24 874 Views
Can Lipo Charger-type C ( SKU: DFR0668 ) connected with Gravity: I2C 3.7V Li Battery Fuel Gauge ( SKU: DFR0563 ) ?Since i want to know the battery (lipo) remaining fuel (shown in t... FAQDFR0668SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 1050 Views
i have a problem with this sensor:Does it need to be peeled or opened or anything? because i dipped it underwater and received no reading. Double checked the UART 2 pins, rx to 16,... FAQSEN0599SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 733 Views
Is there a 3D model of this case which you could share? FAQFIT0949SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 872 Views
Can i confirm that the M.2 E Key slot is only 2230 and will not be able to fit 2280 SSDs like the Samsung 990 Pro? The pictures like like it may fit, so i am crossing my fingers he... FAQDFR1141SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 1113 Views
Hello, I would like to know if the accuracy of the NO2 value at the output of the DFRduino UNO R3 (assembled with MICS-2714/SKU:SEN0441) is also 0.05ppm (like that of MICS-2714), o... FAQSEN0441SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 971 Views
Hello, I’ve been tasked with purchasing an Odor Detector, specifically the ‘Fermion: MEMS Odor Smell Gas Detection Sensor (Breakout, 0.5-50ppm)’. However, I’m unable to determi... FAQSEN0571SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 812 Views
Can this display be used on raspberry pi 4 model B FAQFIT0955SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 1010 Views
Can this sensor count people in a room? FAQSEN0623SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 905 Views
I was wondering if the standoffs are removable? FAQDFR0550-V2SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 587 Views
Dzień dobry,Czy silnik będzie działał na napięcie 3,3V? FAQFIT0578SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:23 852 Views
Does it support an OV5640 camera? (5 million pixels) FAQDFR0618SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 907 Views
Please tell me roughly when you are expecting more of these in stock. Thanks! FAQDFR0430SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 724 Views
With many fake DS18B20 sensors on the market - does this one use a genuine Maxim sensor chip? FAQSEN0511SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 1012 Views
I am facing problem in memory card slot whnen ever i try to run the pogram its always saying initialization failed and i try a new one memory card I am facing the same problme but ... FAQDFR0928SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 852 Views
Hi, do you have any sketch or python program for test or demo? FAQSEN0588SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 630 Views
Does this sensor read oil? FAQSEN0485SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 Trending
- 9 DFR0548 IIC Label??
