Hallo, Is there a tax fee for shipping to Indonesia? FAQSEN0343SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 801 Views
Hello, in the product wiki, the following is mentioned: "RS485 requires 2 terminal resistors, and its resistance value must be equal to the characteristic impedance of the transmis... FAQDFR0779SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 630 Views
Does this sensor read oil? FAQSEN0485SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:22 957 Views
Hi, I bought the sensor 6 months back and now the reading is stuck at 0.01ppm and not increasing even while interfering with alcohol. What should I do? FAQSEN0376SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 676 Views
I purchased this product, and it is drawing significantly more than 125 mA at 5V. It's drawing closer to 600 mA. I don't want to drive it beyond specs, so could you please clarify ... FAQDFR0800SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 707 Views
Hello! Do you have more code example for this product?How two arduino board can communicate on this board?Bought it few years ago, but not enough information to use it! Please make... FAQDFR0271SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 647 Views
Do you have some examples how to connect and drive DC motors with encoders from your stock? FAQDRI0004SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 708 Views
Raspberry pi 4 , model B FAQDFR0738SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 604 Views
Hello, my module does not light up until the voltage is over 4.30 V. What could cause this? Can it be fixed? FAQDFR0673SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 723 Views
Very nice. Can the 3 pin plug be specified, and with compatible cables/plug. references.. Be nice to have a dual 3-pin to a single 4pin PH 2.0 plug be available. FAQDFR0996SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 905 Views
Is there an arduino library for this product? Does this library work with it? https://github.com/DFRobotd...Most importantly, is there a way to adjust the sensitivity parameters... FAQSEN0557SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 948 Views
What is the encoder hall sensor specs? Part number or datasheet links? FAQFIT0450SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 823 Views
Hi, I'm considering using this for atmospheric composition measurements. Can this detect ppb level concentrations? FAQSEN0471SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 696 Views
what should I do to make this amplifier withstand 200W, can I put a 2ohm speaker in it? FAQDFR0675-ENSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 639 Views
this module work in 2g? or 3g? FAQTEL0134SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:21 716 Views
I interest the M.2 ethernet card,it's a new product of dfrobot? Can you provide me 3D file ?Thank's in advance FAQFIT0798SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:20 710 Views
Hello,it's possible to reduce the fov at 8°?With 15° the measure is good untill 1.50m, after, for 2.00 the measure are 1.70 to 2.20m.Thank You very much. https://uploads.disquscdn.... FAQSEN0337SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:20 708 Views
Are the resulting points from a scan with this all on the same plane? Therefore if I wanted to collect 3d data I would have to tilt or move the sensor, correct? FAQDFR1022SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:20 833 Views
HelloDo you have sample code for this module? FAQSEN0501SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:20 424 Views
Has this been discontinued, and if not, what is the ETA for stock arrival? FAQDFR0626SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:20 Trending
- 9 DFR0548 IIC Label??
