Problem with Stepper Motor
userHead Account cancelled 2018-09-10 11:46:55 5353 Views3 Replies
I am trying to drive this stepper motor with this driver and an Arduino Uno. I'm powering everything with 6xAA batteries for a total of 9V, which is the minimum rating for the stepper driver.
I am using the code linked on the driver wiki, but I cannot get the motor to move. It does make some humming noises and will hold position, but I can never get it to step for any combination of step size selection or current selection. Can anyone help me get the correct configuration of code and DIP settings on the driver? Is my power supply voltage too low? Is this stepper even compatible with this driver?
Thanks for your help.
2021-06-29 03:26:33 If you're a student from a developing economy, take a look at our list of international scholarships for students from developing countries.
userHeadPic rhysalexander31
2020-12-11 01:38:05 Thanks for the information userHeadPic patricetucker55
2018-09-11 00:55:20 The example code should be good to use, can you confirm the wiring and use another stead power which is larger than 9V to verify? userHeadPic robert.chen
