GPS/GPRS/GSM Shield V3.0 (Arduino Compatible) TCP Connection
userHead 13053167 2015-07-03 01:34:35 11134 Views4 Replies
Hi guys , I'm using GPS/GPRS/GSM Module V3.0 with Arduino UNO to send message to my server using TCP protocol. But I could only find some codes that using HTTP protocol. I have tried to write some codes but my server is not receiving anything and my server can only accept TCP connection.
Below is the code that I wrote myself with reference to other example codes found in the internet.
byte gsmDriverPin[3] = {
3,4,5};//The default digital driver pins for the GSM and GPS mode
//If you want to change the digital driver pins
//or you have a conflict with D3~D5 on Arduino board,
//you can remove the J10~J12 jumpers to reconnect other driver pins for the module!
//Init the driver pins for GSM function
for(int i = 0 ; i < 3; i++){
pinMode(gsmDriverPin[i],OUTPUT);
digitalWrite(5,HIGH);//Output GSM Timing
delay(1500);
digitalWrite(5,LOW);
digitalWrite(3,LOW);//Enable the GSM mode
digitalWrite(4,HIGH);//Disable the GPS mode
delay(2000);
Serial.begin(9600); //set the baud rate
delay(5000);//call ready
Serial.println("AT+CGPSPWR=1\r\n");
delay(2000);
while(Serial.available()){
char x = Serial.read();
Serial.print(x);
delay(2000);
Serial.println("AT+CGPSRST=1\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CFUN=1\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CIPSHUT\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CIPMUX=0\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CIPSTATUS\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CGDCONT=1,\"66.226.75.158\",\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CGACT=1,1\r\n");
delay(2000);
Serial.print(x);
delay(2000);
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CIICR\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CIFSR\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CIPSTART=\"TCP\",\"66.226.75.158\",\"30175\"\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("AT+CIPSEND=91\r\n");
delay(2000);
Serial.print(x);
delay(2000);
Serial.println("$FRCMD,1234,_SendMessage,,0120.40000,N,10314.40000,E,12.0,21.60,10.0,020715,031157.000,1*67"); // message that I want to send
delay(2000);
Serial.println();
delay(2000);
Serial.print(x);
delay(2000);
// put your main code here, to run repeatedly:
Can anyone help me with the coding for using TCP protocol to send data to the server? I would really appreciate it.
Thank you.
Regards,
Nicky
2015-07-10 17:55:01 OK.
Btw , thank you so much.
Regards,
Nick
userHeadPic 13053167
2015-07-09 20:15:03 Hello,
there's page about reference page - GSM-IoT using uno and their GSM module.http://ubidots.com/docs/devices/GSMTelefonica.html?highlight=gsm
I have little experience of IoT, so I could not help now. But I am going to do it recently :)
userHeadPic Leff
2015-07-09 00:29:10 Hi leff,
I didn't try that because currently I only have GPS/GPRS/GSM SHIELD V3.0 on my hand. I got no other shields and I hope I can achieve TCP protocol using this shield. Hope you can help.
Thanks for your reply.
Regards,
Nick
2015-07-04 00:21:24 HI
have you tried some other similar method like wifi shield to send data to the server?
userHeadPic Leff
