Other interfaces of the NFC module
userHead Account cancelled 2016-04-06 17:42:40 2254 Views1 Replies
Hello
I read that UART is only available for the interface of the below product.
http://www.dfrobot.com/index.php?route= ... wRoF_mLRhE
But, I found that the chip said I2C and SPI are also available.
So, Can I use I2C or SPI if I use jumper cables which connects to the chip directly?
2025-08-28 13:41:49
Hi minkoo.cho.kr,
As the user manual indicated, it supports IIC & SPI. You can try to follow its user manual to find related note, sure you have to write your own library.
userHeadPic Leff
