URM37 V4.0
Account cancelled 2016-08-16 14:31:09 1840 Views1 Replies My question is about a LED on the back of the sensor board labeled Active.
If 5 volts and ground are only applied to the board, should I see the Active
LED light up with movement in front of the sensor? If not, under what conditions
will it turn on? In other words, whats it's purpose?
2016-08-17 00:20:42 Hi jrh5628,
If 5 volts and ground are only applied to the board, the Active LED will not light up. Only in the mode of RS232/TTL, the LED will light up. More detailed info you can refer to our product wiki, as shown in the following link:
https://www.dfrobot.com/wiki/index.php?t ... L_Choosing
Wendy.Hu
Wendy.Hu
