Trouble shooting ID01 RFID UHF READER
stevenlucero 2016-08-24 14:34:40 5107 Views15 Replies Hello all,
I'm having some trouble with the RFID UHF Reader. The computer and the read seem to be not talking to each other.
I'm uploading the code as if it was a Arduino UNO. Is there a different board type that i need to use?
If anyone could help, it would be greatly appreciated!!!
2016-09-01 20:48:50 Sweet! thank you! i should try this out and see what happens! Thank you!
stevenlucero
stevenlucero 2016-09-01 20:48:50 Sweet! thank you! i should try this out and see what happens! Thank you!
stevenlucero
stevenlucero 2016-09-01 18:14:44 Sorry, the link as follows:
https://github.com/leffhub/DFRobotSIM80 ... bugger.exe
Wendy.Hu
Wendy.Hu 2016-09-01 18:14:44 Sorry, the link as follows:
Wendy.Hu
Wendy.Hu 2016-09-01 13:36:48 Where can i find that? ive been looking for days and i couldnt find the debugger. id it a download? if so, where do i download it from?
stevenlucero
stevenlucero 2016-09-01 13:36:48 Where can i find that? ive been looking for days and i couldnt find the debugger. id it a download? if so, where do i download it from?
stevenlucero
stevenlucero 2016-08-28 11:36:55 Is the debugger the serial monitor?
And how do i send the code to the module through the serial monitor?
stevenlucero
stevenlucero
stevenlucero 2016-08-26 00:23:03 Hello,
UHF RFID MODULE communicates with pc via USB, not serial communication, so you dont need to download the code to the module, just open the serial debugger, send command to the module, then everything is ok.
Wendy.Hu
Wendy.Hu 2016-08-26 00:23:03 Hello,
Wendy.Hu
Wendy.Hu 2016-08-25 07:54:00 The SKU ID code is TEL0080. I plug in the RFID and UHF module in every usb outlet i have on the computer and it says "COM7"
stevenlucero
stevenlucero 2016-08-25 07:54:00 The SKU ID code is TEL0080. I plug in the RFID and UHF module in every usb outlet i have on the computer and it says "COM7"
stevenlucero
stevenlucero 2016-08-25 00:26:50 Hi stevenlucero,
Acoording to the error in the attachment, probably the board or the com port you chose is not correct. May i know your SKU? Since we have several kinds of readers with different interfaces. It would be better if you can provide me some pictures about your diagram.
Wendy.Hu
Wendy.Hu 2016-08-25 00:26:50 Hi stevenlucero,
Wendy.Hu
Wendy.Hu 2016-08-24 14:34:40 Hello all,
stevenlucero
stevenlucero
