Connection Interval
d.brandonk 2017-04-01 13:31:55 1831 Views2 Replies Hi,
Does anyone know if changing the min and max connection interval changes the data rate that the bluno nano can get? Also, I have a problem that when I change the min and max connection intervals using the AT commands they just revert back to their original settings when the bluno nano loses power. This does not happen, on the other hand, when I change other AT settings. Does anyone know how to remedy this?
Thanks in advance.
Thanks in advance.
2017-04-08 01:54:15 Hi
It seems a little strange. I just did a test and no problem absolutely. The steps are:
1. +++- :Enter At Mode
2. AT-OK
3. AT+MIN_INTERVAL=10-OK
4. AT+SETTING=DEFAULT-OK
5. AT+MIN_INTERVAL=?--replied 20 is different with 10.
So if there are something wrong during your process? Or maybe the module is a defective one.
Wendy.Hu
2. AT-OK
Wendy.Hu 2017-04-08 01:53:47 Hi
2. AT-OK
Wendy.Hu
2. AT-OK
Wendy.Hu
