W5200 Ethernet Module to Teensy 3.2
Account cancelled 2017-07-20 21:52:48 2401 Views1 Replies Hello,
I hope I have posted in the right place.
I am just wondering if someone can help me with the pinout for https://www.dfrobot.com/product-942.html this to a Teensy 3.2 board. Pinout for that board can be found here https://www.pjrc.com/teensy/pinout.html
I would like to use the ribbon cable it comes with, cut one end off and solder the appropriate wires to the appropriate pins on the teensy 3.2. If anyone can assist I would be very appreciative!
Andrew
Andrew
2018-04-05 00:10:48 Do you mean the pin details on the Ethernet module? you can find it on the schematic.
robert.chen
robert.chen
