General DFR0299
dfr0299 microbit mindplus
userHead Gmartin 2022-05-06 21:51:18 1051 Views3 Replies
Hi all !
I am trying to program dfr0299 mp3 module to work with microbit + shield.
While everything seems to be wired correct ( mp3 module plays next or previous mp3 file from sd card when i connect IO/2 or IO/1 with ground) i cant make it play a specific or any mp3 file when i try to program it with mindpluss.
What should i do ?
Thank you for your time in advance !
2022-05-07 21:14:15
Good to know.
userHeadPic R2D2C3PO
2022-05-07 16:55:26
Hi !
I found the sollution by luck. I put the wires (rx tx) in the wrong order and it worked :D
userHeadPic Gmartin
2022-05-07 09:49:06
please share your mind+ code
