[DISCUSSION] Linux on LattePanda
userHead Raymond Day 2016-04-19 04:59:28 466285 Views267 Replies
I order this wanting to run Linux on it. Seems like only the newer 16 type ones will work on it. Can put the ISO on a USB flash drive and it will boot from you on power up.
I had the live one work but installing it would not boot. The only one I found that boots and installs is Lubuntu 16.04. Or:
Linux Lattepanda 4.4.0-18-generic #34-Ubuntu SMP Wed Apr 6 14:01:02 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
It seems to be working very good.
Did you know this Lattepanda has the same CPU in it as the Intel Compute Stick with USB 3.0 on it too. STK1AW32SCR type.
-Raymond Day
