Unknown LP Alpha connectors
anonymous 2018-10-16 16:22:10 2839 Views1 Replies Hi,
There is a white 10-pin white-colored low-profile connector on the back side of LattePanda Alpha. It's on the long side of the PCB and is on the same side of the Intel WiFi Module. (not on the flat panel display/touch FPC connectors side)
What is it used for?
Also, there is a two-pin "SW" connector. It seems to be not for Power Switch (since there is already a soldered push button switch just for that purpose.) Can you explain its purpose?
Thanks!
ccs_hello
Thanks!
ccs_hello
