Data connection over microUSB cable
userHead mikemar1818 2018-10-17 15:08:01 1837 Views1 Replies
I know that the LP can be powered over the microusb connection. If the LP is connected to a powered USB hub (connected to a PC). What type of downstream device does the LP show up as on the PC ?
| PC | <-----> HUB <---> LP
|____|
Basically can I communicate some way with the latte panda over the microusb cable from a pc ?
