【FAQ and Tutorials】 for LattePanda 3 Delta x86 Windows Linux SBC
userHead LattePanda 2023-03-15 18:36:33 5070 Views2 Replies
Hi guys,
Here are some frequent asked questions(FAQ) of  LattePanda 3 Delta  in our forum. For a detailed product user manual, please refer to 💡 LattePanda DOCS.
Thanks to our great forum contributors!! 👏
🥪 BIOS Update
Reflash BIOS firmware on LattePanda Board using CH341A Programmer
🍗 Problems & Solutions
1. Restoring the Missing COM Port for Arduino Leonardo
2. Fan not working on my new Lattepanda 3 Delta
3. Screen Flickering Issues when connecting other eDP displays
4. How to set the Arduino pins always on
5. Problem with RS232 on LP 3 Delta using Windows
6. Triple Display Solution for LattePanda 3 Delta 864?
7. Fan not working on my new Lattepanda 3 Delta
Auto Power-on
8. How to Set Auto power-on for LattePanda 3 Delta
9. Use the Onboard Arduino to enable LattePanda 3 Delta to auto power on
10. LattePanda 3 Delta failed to auto-start
💟 Watchdog
11. Programming the Watchdog Timer of LattePanda 3 Delta
12. Using the Arduino Chip of LattePanda as a System Watchdog
📶 Network Connection
1. Telit Modules Connectivity Issue on LattePanda 3 Delta
2. 5G module doesn't work on Ubuntu
3. Cellular Connection Issues on LattePanda 3 Delta with a 4G Module
4. Fix Internet Sharing Issue with Wi-Fi and Hotspot Adapters
🆒 Cool Projects & Tutorial
1. Show your LattePanda Cyberdeck to win FREE LattePanda 3 Delta
2. Point And Click Systems: Bringing the DAW and DVW to Eurorack with LattePanda
3. LattePanda Compatible Accessories Recommended by Our Community Members
4. Use PlatformIO to program Onboard Arduino GPIO on LattePanda
5. How to Use Serial Redirection on the LattePanda 3 Delta
6. How to Setup Wake-on-LAN (WOL) for LattePanda Series Boards
7. How to Generate a UUID for LattePanda Models
8. Running Android On LattePanda Using Waydroid
9. How to quickly Identify Pin 1 of eDP Panel
10. adding a RGB Power Switch to show Power State and D13 Pin status
11. How to Control System Volume via the Integrated Arduino Leonardo?
12. Ideas for Containing LattePanda EDP Touch screens
13. LattePanda Portable Music Studio
14. Stellar Captures: Enhancing Astrophotography with LattePanda 3 Delta
📝 Documents
LattePanda 3 Delta 3D file
📋 Certification
LattePanda 3 Delta CE FCC RoHS KC Certificates
Continue to update...
