Type c Charging & screen output???
userHead yoonho.cho 2023-03-15 18:54:56 1065 Views1 Replies
Is it possible to distribute type c to two from Latte Panda 3 Delta, one with 3 Delta pd power charge and the other with display output?
If possible, which type c hub, distributor should I use?
thank you for help :)
