Lattepanda Sigma eGPU not functioning
userHead Solaris17 2023-10-06 13:51:43 2979 Views1 Replies
Hello. I am trying to troublshoot an issue I am having with my eGPU enclosure and my sigma.
The Sigma states that it supports thunderbolt egpu devices:
https://docs.lattepanda.com/content/sigma_edition/IO_Playability/#usb-type-c-portthunderbolt-4
https://docs.lattepanda.com/content/sigma_edition/Display_Connection/#usb-type-c
I use a razor core x for my egpu enclosure. It functions fine on my other PCs.
https://www.amazon.com/Razer-Core-Thunderbolt-External-Enclosure/dp/B07CQG2K5K
Lattepanda states that both usb-c ports are thunderbolt 4 compatible
However the egpu enclosure only shows up when plugged into port 7. It does not show up when plugged into port 1.
Further, even when plugged into port 7 the gpu in the enclosure is not seen. Only the enclosure. I thought that maybe the GPU was the issue so I swapped them but it still was not seen.
Thinking it was the cable I bought a new cable but still the GPU was not seen.
I then plugged the egpu into my primary desktop and it worked without issue. So I was able to rule that out.
Thinking maybe the BIOS was the issue I reset to default but the problem persisted.
Finally; I figured this may be an issue with the BIOS version I'm on so I flashed the latest provided by lattepanda here (I have the 16gb version):
https://github.com/LattePandaTeam/LattePanda-Win10-Software/tree/master/BIOS%20for%20LattePanda%20Sigma/16GB%20version
I STILL have the issue, but others appear to be able to use external enclosures without issue (taken at time)
https://www.youtube.com/watch?v=rVai4eszBB4&t=671s
I installed a second NVMe drive. Could this be an issue? The CPU should still have plenty of pci-e lanes left. Maybe I need to modify the BIOS configuration?
Any help would be appreciated I have had this about a week and im getting frustrated.
