Latte Panda Delta v3 SPI Chip Select pin not Working
Md khalilur.Rahman 2023-11-24 01:10:05 1802 Views8 Replies The Latte Panda Delta 3 SPI Chip Select pin not Working.
- Latte Panda Delta 2 Connected to an Oled spi display is working
- Latte Panda Delta 3 Connected to the same Oled spi display is not working.
- When we keep the OLED display chip select pin low by hardware, Latte Panda Delta 3 Connected to the Oled spi display is working.
- Selecting some other pin as Chip Select is also not working with the Delta 3, but working with Delta 2
Looks like noise in the GPIO or the pin mapping issue however, the Arduino can control the on-board LED. Has anyone faced a similar problem with the Latte Panda Delta 3?
