Hi! I would like to know if such a board supports:- bluetooth module http://www.dfrobot.com/inde...- LCD shield http://www.dfrobot.com/inde...at the same time. Are those board usin...
userHead JaneYu 2015-10-10 04:11:12 21 Views3 Replies
at the same time. Are those board using different pins? Do they fit together within that limited space (any gap between the top bluetooth xbee module and the bottom of the lcd shield?)
Thanks in advance.
2018-01-07 18:32:59
How can i Implement this for softwareserial? What are the pins should we use? Thanks
2016-12-29 22:06:33
This controller is not detecting the Wifi Bee ESP module, does anyone know the reason?
2015-10-10 06:02:33
So the xbee bluetooth is actually not working on this model? Are u sure?
Can someone of df robot reply to my questione?
Can i use the bluetooth xbee (TEL0023) and the LCD shield with the 5buttons joystick (DFR0287) on top of that?
