Mini WIFI Dongle For Raspberry Pi x 1 is not included in the box. It needs to be removed from shipping list and introduction. And flame sensor is not included. Introduction needs ...
userHead JaneYu 2016-05-05 11:11:19 10 Views4 Replies
Mini WIFI Dongle For Raspberry Pi x 1 is not included in the box. It needs to be removed from shipping list and introduction. And flame sensor is not included. Introduction needs to be modified.
2016-08-15 01:02:46
hi dfrobot! is this kit compatible with pi 3 model b?
2016-05-06 12:13:52
I'm not sure Mini WIFI Dongle ( Realtek8188CUS chipset) is compatible for Windows 10 IoT. You should Check it out below.
https://ms-iot.github.io/co...
2016-05-06 12:12:05
I meant that there's no 'Optional' mark at Mini WIFI Dongle For Raspberry Pi. Optional mark is at Broadcom WIFI Adapter and 2 Port USB Hub for Raspberry Pi. And Broadcom WIFI Adapter does not exist in DFRobot Store. It might have been sold in the past but not now. There's Broadcom WIFI Adapter in the option combobox but not Mini WIFI Dongle For Raspberry Pi.
So, I suggest that you should remove item Broadcom WIFI Adapter and 2 Port USB Hub for Raspberry Pi from shipping list and option combobox. You need to mark 'Optional' at Mini WIFI Dongle For Raspberry Pi.
The sentence needs to be modified in INTRODUCTION "The included WiFi module makes it possible to connect to the Microsoft's "Azure" Cloud service easily where you can upload your sensor data to the database." WiFi module is not included in the box. It's an optional item. The correct sentence is "You can select WiFi module that makes it possible to connect to the Microsoft's "Azure" Cloud service easily where you can upload your sensor data to the database."
Thank you indeed and sorry for the mistake. We've corrected the description according to your opinion. But the boardcom wifi dongle will be still in the option, this dongle is special for Raspberry Pi, Mini wifi dongle will be removed. Thanks again.
2016-05-13 14:28:18
